跳转到主内容
加入维修社区 - 创建账户
爆米花机及爆米花制作器的维修指南。
Popcorn machine mains problem
A popcorn kettle on the bench. It was reported to trip mains fuse. When testing it I measured 1.3 kW. But kettle was marked 500 W. I opened it up and could not see or measure anything faulty. Cables and grounding was good. But there were rust on the thermostats nuts. I cleaned the nuts and rusty residue on the thermostat. Put everything back together and now the kettle measure 500W and the thermostats works. Is it possible that the thermostats was faulty due and the reason for it to draw 1.3 kW instead of 0.5kW?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@seafoamgreen absolutely. SInce everything is looking like it is in good working order, and it does not pop the mains fuse, I would say you got it fixed. Could be bad thermostat, bad connections corroded connections etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 26
总计 374
