跳转到主内容
加入维修社区 - 创建账户
Panasonic TX-32LX70 是一款来自 Panasonic 的 32 英寸液晶 (LCD) 高清电视。
Sound and no picture
Please guys, I need some help, my TV is a Panasonic model TC-32LX70LB, and i don't speak english very well, what happen is that when I turn the tv on, the sound works normally, but the image does not appear, and makes a sound like something is trying to work mechanically, i don't know how to explain exactly, but after some time, the image started to appar gradatively, however after a few months of that now only works the sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@marjorieronzani you are not saying if your power LED blink when your pictures is dark. First you want to try all other video inputs, things like HDMI, Component etc. Next try to see if your TV still shows the TV menu when you push that on your remote.
Now turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components.
Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board or a backlight inverter.
Your TV uses CCFL tube as backlight. It is possible that these have burned out. Those function in principle the same way as fluorescent light bulbs.
If you have any trouble translating this, let us know what your native language is. We can always try to rephrase or translate the more confusing issues. Welcome to iFixit!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MARJORIE RONZANI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 249
