Why the mechanism of the brushes almost do not move
It used to do its job as intended, but now for some reason the brush mechanism barely moves, making it difficult/impossible to clean. I don't know what could be the problem, please help..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@nevergiveup7156 we need to at least know the make and model for your vacuum. It could be the brush motor, bad battery, bad firmware or some mechanical obstruction. Time to take it apart and to have a look.
完成的
Yep, you should also refer to your manual if you have one it may tell you how to check the brushes for obstruction.
完成的
添加一条评论
