跳转到主内容
The Craftsman Chain Saw 316.350851 is an air-cooled, 2-cycle 55cc chainsaw designed for various cutting tasks. This page provides repair and further information about its electronic ignition, fuel/oil mix system, auto-rewind starter, and other features.
primer bulb fuel lines
change fuel lines on primer bulb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Is there a question? Be as descriptive as possible when pointing to a problem.
完成的
添加一条评论
1个答案
You will need to get out your owner's manual repair manual and look for a diagram sometimes called an exploded parts diagram. In here you should able to find the primer bulb, get the part number, and order new, either from a local dealer or online. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 26
