跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
Correct thermal pad thickness
Hello, is there any consensus on what the thickness of replacement thermal pads should be? I've seen both 1.5 and 1.0 mm. 1.5 mm seems to be more common, but I haven't found any definitive proof.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi!
I used the 1.5mm ones and they are working fine. I recommend to use the 1.5 thickness.
I guess the 1.0mm ones are working fine as well, but I only have experience with 1.5 ones.
这个答案有帮助吗?
得分 3
2条评论:
Thank you for the quick reply! Do you think it's generally a good idea to replace them if I'm opening my PS5 to clean it anyway?
完成的
My pleasure! If you are going to remove the heatsink and plate, check the thermal pads first. If they are full with dust or are broken, then you need to replace them! Also, replacing the liquid metal is a good idea too if you want optimal cooling performance. Be really careful with this tho, it can leak or you can spoil on the motherboard.
完成的
添加一条评论
添加你的答案
TempQ 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 115
总计 2,247
