跳转到主内容
加入维修社区 - 创建账户
Lenovo Y50-70 Touch 发布于 2014 年 8 月,属于联想 Y 系列笔记本电脑。Y50-70 Touch 配备了独立显卡和 15.6 英寸触摸屏,专为游戏设计。
How do you repair usb controller?
I bought a motherboard that works mostly except that the usb ports don’t work. I’ve tried plugging in a mouse to the ports and the mouse does not work. When I plug it into the port not attached to the motherboard, I get a power surge.
Is there any way to find the chip that controls the usb ports and replace it with a chip from another board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
@gregoryvenezia sure, anything is possible. Here is the challenge. WE need to know what motherboard your Lenovo uses. It will be printed right on the board, most commonly on the side that faces the keyboard :-)
We need this so we can determine if there are any schematics to identify the IC and find a replacement for it.
完成的
My motherboard is LA-B111p.
完成的
I have a soldering iron and a heat gun. I don’t know how to re-ball solder.
完成的
@gregoryvenezia
Did you check the USB power management setting in Device manager to see that the USB power hasn't been disabled?
Go to Device Manager > Universal Serial Bus controllers > right click USB root hub entries (check all of them) > Properties > Power management and ensure that the checkbox which states "Allow the computer to turn off power to the device" is unchecked.
Also check in BIOS if there's a setting allowing the USB ports to be disabled.
完成的
What about the power surge?
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Hi @gregoryvenezia
Here's a link to the schematics.
Do the USB ports show in Device Manager?
If so that indicates that the USB controller (it is integrated in the motherboard chipset and is not an individual USB controller) is working, up to a point anyway i.e. BIOS to USB controller is OK but not USB controller to USB port.
You will have to trace the 5V USB power supply and the data lines back from the USB ports using the schematic and check where they end up.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gregory Venezia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 315
