跳转到主内容
Released 1993, identified by word TI-82 labeled on upper right corner of the screen.
8 个问题 查看全部
One key is not working anymore
The calculater works fine except the key for "3" doesn't do anything.
Is it easy to fix this?
I cannot seem to get it open.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Oh. If you can't get it open (i dont have a texas instuments calculator), there's not much you can do. I can't think of what you can do. Im sorry.
完成的
添加一条评论
1个答案
最有帮助的答案
The calculators have plastic snaps that firmly hold it together. It takes some determination and spudgers (or screwdrivers) to take apart.
Once inside you can take out the circuit board and clean the button side with isopropyl alcohol. You can also clean the rubber membrane while you're at it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
PHB 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 17
