跳转到主内容
加入维修社区 - 创建账户
三星 Galaxy A04s 是一款经济实惠的智能手机,配备大尺寸显示屏,电池续航时间表现出色。它提供适合日常使用的基本特性和功能。
My phone looses touch
After some time I have to forcefully reboot my phone because the screen can't be touched
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@frankcheruiyot could be caused by the touchscreen failing or by the touch IC failing. I would start with the easier one which is replacing the display assembly which does include the touch screen. Since iFixit does not yet have a specific guide for that, either use something like this guide or this video The guide is written in French so use a browser that does the translation for you (if needed). Replacement display assemblies are readily available at many online stores.
Should a new display assembly not fix this problem, then you will need to check your mainboard. For that you will need some decent tools as well as the ability to solder very small components on a very busy circuit board. Let us know if that is something you would want to tackle.
Of course, a few other things before doing all of this is to check your software. Make sure that all of your software has been updated. If that does not help, consider doing a factory reset. Before doing that you will need to backup all of the files (SMS, Contacts, Music, pictures etc.) from your phone since all of those will be deleted. You also need the username and password for the google account you've used to originally setup your pone. If you do not have those, you can't easily access your phone after a reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FRANK CHERUIYOT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 283
