跳转到主内容
加入维修社区 - 创建账户
Which graphic card support?
In this dekstop which graphic card is support???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@soumenmaji there are actually quite a few but these are the common ones:
GPU upgrade options for Lenovo ThinkCentre M82 Tower with the stock 450W power supply
GPU Power consumption Memory Req.
NVIDIA GTX 1660 Super 130 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1660 Ti 125 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1070 145 W 8 GB DDR5 *Dual SATA to PCIe adapter
NVIDIA RTX 3050 130 W 8 GB DDR6 *Dual SATA to PCIe adapter
  • Typically, the stock power supply in a business PC does not have the necessary 6 or 8 pin connectors to power the GPU. In such cases, you may need to use a low-power GPU or a SATA to PCIe power adapter. Alternatively, you can change the entire PSU. from here
To work on your Lenovo use this ThinkCenter Hardware Maintenance Manual
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
SOUMEN MAJI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 416
