Blue screen error problem due to RAM
Blue Screen error problem due to RAM
@prayag57802 since you are certain this is caused by a bad RAM module, it is time to change it. Of course, you can also try and clean teh contacts first. I use a pencil eraser to clean the contacts. Also, inspect the RAM slots on your motherboard to make sure that there are no bend or corroded pins etc.
To work on your computer use the Dell OptiPlex 790 Desktop Owner's Manual which essentially is the service manual. Now, if you are just guessing that this is a RAM error, then you have to give us more information about what your computer is doing and what you have tried.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 302
Hi @prayag57802,
Did you change/increase the memory?
If so what type and how much memory did you try to install?
Also if you added more memory, does the PC work OK with the original memory that was installed?
由 jayeff 完成的 分享
