跳转到主内容
加入维修社区 - 创建账户
Acer Extensa 2509 搭载 Intel Celeron N2930 处理器和 Intel HD Graphics 核芯显卡。
How to fix no bootable device
When I cut it on it says no bootable device and when I switch to legacy it says no bootable device and something else I can't remember what.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@loganterry27045 sounds like your Acer can no longer read the information from your HDD. You first want to check the BIOS and see if your HDD still shows up. If so, you could try and use something like a Linux Live boot disk and see if you can boot your computer up and then access your HDD. The seam will hold true if you have an SSD in your computer. If you still have a HDD then you might consider replacing it with a faster SSD.
If you can't access your HDD, or it is no longer seen in the BIOS, you will have to consider replacing it and reloading your OS. Your files on the old drive are consider lost. Here is how to work on your laptop and around the 5 min mark it'll show how to remove the HDD
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Logan Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 45
总计 356
