跳转到主内容
加入维修社区 - 创建账户
Sony Bravia 42" 液晶电视的维修信息。发布于 2012 年。型号:KDL42EX440。
Screen Shadowing After Turning it on For a while
at First It the screen was normal,but after a while its starts shadowing everything and make it blurry its like the image is doubled,after we turn it off for while,and it went back to normal and after like 20 minutes its starts shadowing again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@agilzachry verify that your TV is a KDL42EX440. If so, then the prime suspect is the T-con board. You'll find that the Gamma IC is either failing or part of the IC power supply is failing when it heats up.
这个答案有帮助吗?
得分 0
2条评论:
its KDL-40R350B
完成的
@agilzachry time to check the boards. Post some pictures of the circuit boards with your Question so we can try and identify the Gamma IC for your model
完成的
添加一条评论
添加你的答案
Agil Zachry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 229
