跳转到主内容
加入维修社区 - 创建账户
2015 款 Sonata 内部代号最初为 LFA,于 2014 年 3 月下旬在韩国首次亮相,随后在 2014 年纽约国际车展上于美国正式发布。
Changing front bumper out
Replacing front bumper, thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @simon52118,
What is the year model of the vehicle?
完成的
Also, are you referring to the metal bumper itself, or just the bumper cover that goes over it?
完成的
添加一条评论
1个答案
最有帮助的答案
@simon52118 these don't have much of a bumper behind the cover. You'd be more looking at the radiator grill. Anyhow, this from the service manual 2014 to present:
1. Front bumper cover
2. Front bumper side bracket
Replacement
  • Put on gloves to protect your hands.
  • When prying with a flat-tip screwdriver or use a prying trim tool, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
  • Use a plastic panel removal tool to remove interior trim pieces to protect from marring the surface.
  • Take care not to bend or scratch the trim and panels.
1.Loosen the front bumper upper mounting clips.
2. Loosen the front bumper lower mounting clips.
3. After loosening the front bumper (A) side's mounting clips and screw, then disconnect the side's.
  •   Remove the front bumper by pulling up the side of the front bumper and then pull it out.
  • When you pull out the front bumper, the side part of the front bumper could be damaged by the projection.
4. Disconnect the front bumper main connector (A).
5.Remove the front bumper cover (A).
6. Install in the reverse order of removal.
  • Make sure the connector is connected properly.
  • Replace any damage clips.
If this is not the right model, then you need to let us know the exact year for your Sonata!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 635
