跳转到主内容
加入维修社区 - 创建账户
error code C00D124D
When ever i try to download music i get error code C00D124D on the computer however the Zune itself is frozen on 16% syncing. Theres still the flashing dots in the back round but it says at 16 %
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@willy10879 that is an update error but can also be a HDD error. You also want to try different USB ports and maybe even a different cable.
We do want to be careful so that you do not delete the files on your HDD, but you can try a recovery. To enter Recovery mode – Press and hold the power and media buttons for 15 seconds. The device reboots into Recovery mode (content is not erased, allows for firmware reinstall). This is a good option if you want to keep the content on your device, but reinstall the firmware. You may need additional software,. Check this video and download the files from here
If none of that works, you may have to consider replacing your HDD. Your Zune should come apart just like the Zune 80/120 Microsoft Zune 80 硬盘更换
All of this is a bit of a beast to work on. The drawback of working with legacy devices.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Willy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 405
