跳转到主内容
加入维修社区 - 创建账户
长方形外观 / 16 GB 容量 / 2012 年 9 月 12 日发布
I think heat damage?
Mine has been through the washer and dryer. The screen looks damaged below the glass, and it doesn't turn on. I plugged it into my computer and it said it was charging. It also plays music when I put my earbuds in it but the screen is dark. What should I do to fix it and what parts would I need?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@danikalodholtz neither the washer nor the dryer were any good for your iPod. The worst part is the washer. Your iPod is most likely water damaged.
For now, I suggest that you stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your iPod.
The next thing to do is to clean it. Use this guide iPod Nano 7th Generation Logic Board Assembly Replacement - iFixit Repair Guide to remove the logic board etc..
After you removed the board, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide, it was written for an Apple iPhone 3G but all the points are still pertinent to your iPod as well. While you clean your board, check for any obvious damage, like burned or missing components etc. I cannot stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your iPod and reevaluate. Until it is cleaned, everything will only be a guess.
It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPod Nano 7th Generation 逻辑板组件图片
指南
iPod Nano 第 7 代逻辑板组件更换
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danika Lodholtz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 218
