跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 17R-N7110 是一款配备 Intel Core i3 或 i5 处理器的 17.3 英寸笔记本电脑。
Display bad after humidity
Yes, it's an old laptop, and I left for 2 weeks, and it rained and it was humid and now the laptop's display doesn't work - there's backlight but its all grey. Occasionally some faded image will peep through from behind. secondary display works fine. How do I fix it? clean the corrosion with ISO alcohol?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@breathlungs absolutely. I would try and clean the display connector and the cable ends with sum +90% isopropyl alcohol. Next use the Dell Inspiron N7110 Service MAnual starting on page 89 and disassemble the display. Clean those parts as well. The only thing you can't clean is the inside of the LCD, that is the only drawback right now.
If none of that works, you would have to consider replacing the display. For now, clean it well and see what is going on with it.
这个答案有帮助吗?
得分 2
2条评论:
Thanks. Is it ever possible to figure out where the corrosion might be by looking at the failing display and how its glitching? Or is it still just a guess either way?
由完成的
@breathlungs no way to pinpoint a component for us, since it is a signal issue and not a power issue. You would need to have the complete schematics for the driver board and then use an oscilloscope to check those data lines. In your case you will have to stick with the general approach and consider any component as the culprit.
由完成的
添加一条评论
添加你的答案
Seymor Butz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 259
