Why is it not charging?
When I plug in to charge it doesn't show that it's charge, no charging light nothing. Please Help.
@tina3793 so it doesn't show you any sign of life. It is dead, not just not charging. Make sure that you first check your power supply. Should be a 12V 8A adapter. Then check the power jack. Make sure it is not bend, corroded or has debris inside of it. Next you will have to check the power board. For that you want to dismantle your PartyBox
Once disassembled post lots of pictures of your boards etc so we can check them with you.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 654
JBL encore party box not carging
由 Mohamadrofii 完成的
Do I have to replace the carging cable
由 Mohamadrofii 完成的
What do I do please
由 Mohamadrofii 完成的
My jbl partybox encore carging 14% only..what happen
由 Mohamadrofii 完成的
