跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note 3 智能手机由小米公司于 2016 年 3 月发布。它配备了一块不可拆卸的 4050 mAh 电池,并支持最大 256 GB 的可扩展存储。
Phone is not switch on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@vaishnaviotari if you are seriously expecting some help with that, you will need to give us more information. Right now, there is not a single specific answer that will be resolving your phones issues,. If you want help fixing it, help us to help you and give more information.
Since our goal is to empower people to fix their own devices, here is at least a generic answer that show that we are willing to go the extra step. Even on minimalistic questions than this.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
You will also need to check the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables. Since iFixit does not yet have a guide for the replacement of the charging board, use the one from here It is written in spanish. Use a browser that does the translation for you.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vaishnavi Otari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 205
