跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Core Prime Duos Android 手机是 Samsung Galaxy Core Prime 系列的一款变体。型号为 SM-G360H/DS (SM-G360H/Dual-Sim)。发布于 2014 年 11 月。
It doesn't charge
When I plug the charger it just keeps on vibrating.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@tee48976 sounds like your phone does not get the full current to charge. It could be that your charging port is failing or maybe even your cable.
First check your charger. Make sure it has proper output and ensure that you use the charging block and not a Hub or USB port on a computer etc.. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tee 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 280
