跳转到主内容
加入维修社区 - 创建账户
Logitech MX Anywhere 3 便携式无线鼠标的维修和拆解信息。该设备于 2020 年发布,型号为 910-005986、910-005833、910-005987 或 910-005985。
Click is not working
Hello everyone!
Well, I have MX Anywhere 3 and I have now this issue: left side is not clicking. You need a stronger click/click in a precise spot of this side of the mouse to make the click work. I have this product for more than 5 years now. I saw there are some videos about how to fix it at home... and I am a bit afraid buying the tools/paying someone to fix it and then having the issue again...
Do you guys have any tips or instructions that I could follow to solve this problem? Have you faced this problem as well? Is really worth fixing it?
Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
@amandazorzhan "bit afraid buying the tools/paying someone to fix it" first off you are not going to pay anyone. This is ifixit where YOU are empowered to fix it yourself. You can absolutely do it. You know to use this excellent guide 如何打开 Logitech MX Anywhere 3 and not some shaky youtube video ;-)
Now this "need a stronger click/click in a precise spot" sounds like an issue with the micro switch. It could just be that the plastic is starting to wear a bit. 5 Years is actually a really good life expectancy. Now, once your mouse is apart, take a look at those pieces.
If you find that they have worn. Get some nice adhesive and just add some "mass" to it. I commonly use little felt pads from the larger department stores and cut a small piece and glue it on top. Less rigid gives a better mileage :-)
There is a whole community of fixers here that is willing to help you, if needed. No worries, You got this!
Repair is War on Entropy!
这个答案有帮助吗?
得分 3
3条评论:
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
由完成的 分享
I added two layers of regular adhesive tape and it did the trick. Thanks!
由完成的 分享
I added four layers of Scotch tape, and it seems to be working well. that does wear out because it does compress over time so you might need to do it again
由完成的 分享
添加一条评论
Hi Amanda, I believe the only way is to open it up and clean the button with rubbing/ isopropyl alcohol. One think you could try is using compressed air to clean under the area.
这个答案有帮助吗?
得分 0
1条评论:
由完成的 分享
添加一条评论
I've tried both usual methods, using lubricant on the micro buttons inside the mouse and blowing air inside, but neither worked.⏎
I also noticed that if I use the mouse without the cover, the left click and double-click work fine, so the problem isn't with the buttons inside but with the buttons on the cover.
这个答案有帮助吗?
得分 0
1条评论:
There are 3 screws on top cover, if you take those out you can actually see interior of the buttons and use a thin brush to clean up all the dust i did this and my mouse was fixed
由完成的 分享
添加一条评论
添加你的答案
Amanda Zorzhan 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 132
过去 30 天: 554
总计 15,306
