跳转到主内容
加入维修社区 - 创建账户
一款 Realme 中端手机,于 2020 年 9 月 14 日发布。搭载骁龙 720G 处理器,配备最高 8 GB 运行内存和 128 GB 机身存储,并拥有一块 6.4 英寸 Super AMOLED 屏幕。
power button and volume button also not working
Call is running baground power button is not working for switch off and volume button also not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
@jayarajtriparna is this a question or an answer? I am confused by this. If it is a question, let us know what make and model your phone is. Next, let us know what does not work and after that, let us know what you have tried. Give as much information as possible so we can try and help you.
由完成的
@jayarajtriparna this was left as an answer to a separate question. It has been converted to its own question.
由完成的
Speaker problem
由完成的
添加一条评论
1个答案
@jayarajtriparna this "power button is not working for switch off and volume button also not working" sounds like a bad flex cable. The power button and volume buttons are on the same flex. Replacement flex cables are readily available at many online stores.
To replace the power button flex. Since iFixit does not yet have a guide for that , use something like the one For that use something like the one from here It was written in Spanish so use a browser that can translate it for you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaya raj Triparna 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 45
总计 1,094
