跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 于 1996 年 6 月 23 日发布,型号为 NUS-001。它是任天堂的第一款 64 位游戏主机,也是在 Switch 发布之前唯一的 64 位游戏主机(GameCube、Wii 和 Wii U 虽然可以进行 64 位浮点运算,但并非真正的 64 位架构)。
Incredibly dark image - help!
Hi,
Found my old N64 tucked away and trying to get it to work.
It’s on a SCART cable, and I get audio just fine, but the image in the screen is INCREDIBLY dark. Like not there at all. With brightness/contrast settings cranked on the TV you can just about make out the image.
I’ve re-seated and cleaned all cables and the expansion pack, and tried multiple games
Any ideas?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hey there, are you trying to play your N64 on an HD TV or using a CRT TV?
由完成的
HDTV.
Thanks
由完成的
Have you tried using different games, and tried cleaning the N64 cartridge’s pins?
由完成的
@spawn2048 how do you connect your N64 to your HDTV? Have you tried an older TV? what make and model is your TV?
由完成的
@jmehnert yes, as stated in the original question…
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
I advise to clean the AV port first. If that didn’t worked, then replace the AV cable for a new one. If that didn’t worked, then try the console on a different TV to determine if there is something wrong with the console. If the image is like still super dark, then open up the console and clean it all (also the cartridge pins on the motherboard) and try again.
Could you also share some pictures regarding how the console is connected to your TV?
Please let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
Bit the bullet and bought a new cable. Now on AV rather than SCART and working fine. So either broken cable, or broken SCART port on TV
由完成的
Hi!
Alright. Probably the cable (in most cases). You could try the SCART port with the new cable. Could be the SCART adapter as well. Good to hear that all is ok now :)!
由完成的
添加一条评论
添加你的答案
spawn2048 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 27
总计 1,041
