跳转到主内容
加入维修社区 - 创建账户
Ghost touch on phone
How to fix a ghost touch on my phone screen,? Any one ?
When I use my phone it change by itself like logging me out or clicking back arrow or writing wrong words things like that. It's very annoying and feel frustrated when using my phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
I appreciate your time and possible solution to this matter but I think it's time to get new phone. Thanks.
由完成的
My phone is blinking off and on it's shutting down it's frequently freezing and I have to I can't turn it off I can't do anything with it it's literally like freezes my screen and I can't load up anything I can't change the app I can't do nothing I've cleaned out that everything I have had to do and every time I do I can't get on to my Gmail accounts my apps that I put on my phone I can't get on and anything and it's very aggravating it's not sinking right nothing
由完成的
添加一条评论
2个答案
已选择的解决方案
This is a common problem with some phones— ghost touch is usually caused by a touchscreen malfunctioning due to physical problems, such as a low quality digitizer, a damaged screen, dirt under the screen, or water damage. My recommendation is that you should get your phone cleaned under the screen (protector) and make sure that there is no dirt left. If that doesn’t work, try resetting. :)
这个答案有帮助吗?
得分 3
1条评论:
You are right in that recommendation or solution to this matter. Thank you.
由完成的
添加一条评论
@grace74377 that is an issue related to a bad display assembly. The digitizer (touchscreen) is malfunctioning ( there are technical reasons for it but too long for here) Replacing the display assembly will fix this.
First make sure you try and remove your screen protector, just in case that is what causes the issues.
Use this guide Motorola Moto G Stylus 5G (2022) 屏幕更换 to work on it
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your input in this matter, I think the best solution will be buying a new phone. Best regards.
由完成的
添加一条评论
添加你的答案
Grace 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 166
总计 5,828
