跳转到主内容
加入维修社区 - 创建账户
Sony Cyber-shot 系列数码相机。可拍摄 600 万像素照片,发布于 2006 年。
Lens is stuck halfway
My Sony DSC-H2 was working fine until recently. The word 'Access' appears when you start it up, indicating that there's a problem with extending the lens. The image is fuzzy and can't be focused. When I try to power it off, it tries about three times to retract the lens but then gives up and leaves the lens half out.
I've tried new batteries and a factory reset of the camera.
Any help appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Tengo una de este tipo y le dieron un golpe y al encender el lente no trabaja no enfoca
由完成的
添加一条评论
1个答案
最有帮助的答案
@randominion7494 your camera has a stuck lens. Try the tips fromthis site If none of that works, you may have to replace the lens. To work on it use this teardown Sony Cyber-shot DSC-H2 拆解 and the Sony instructions right here DSC H2 Disassembly
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your suggestion.
由完成的
添加一条评论
添加你的答案
randominion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 486
