跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad 5 15IIL05 的维修与故障排除信息。这款基于英特尔处理器的 Lenovo IdeaPad 5 笔记本电脑于 2020 年发布。内容包括设备识别详情、技术规格,以及铰链和电源按钮问题等常见故障。
Hinge Broke LCD Display
My laptop is about 3 or so years old and has been dropped a few times, however it wasn't until recently that the back right hinge broke off from the LCD Back Cover breaking some of the plastic off with it. I am trying to figure out what I am needing to buy in order to repair it. Any idea what I am needing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
@andrewboot16282 most likely the ninges since they got stuck, unless you get them to move smoothly again. Soak those in some WD 40 and continue to work them until they are no longer sticking. Lubricate them after they are clean and dry with some 3-in-1 oil and work it into the hinges by opening and closing those a couple of times. If the hinges are bend or otherwise damaged, you will have to replace those.
Next parts to replace would be the middle frame where the hinges screw into and the LCD cover. Now, we do not know the condition of the top case, that is the part where the keyboard sites in etc. That you will have to evaluate as you open your computer.
To work on your Lenovo use the Lenovo IdeaPad 5 15IIL05 Hardware Maintenance Manual
这个答案有帮助吗?
得分 0
添加一条评论
My laptop hinge broke twice and this is the third time. The screen was not damaged. Can this be fixed?
这个答案有帮助吗?
得分 0
1条评论:
@marialopez49572 possibly but we need to know more about it. Make and model is a good start. How did you fix it the first two times?
由完成的
添加一条评论
添加你的答案
Andrew Booth 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 104
总计 1,840
