Blue connection not turning on
When I try to enable my Bluetooth through the status bar or in the settings the nob Icon will not turn on. However my wifi connectivity still works perfectly
@bwalyamataka since your WiFi still works you may have issues on a component level. First you must rule out that this is a software issue.
First start your phone in safe mode. To place it in safe mode, use the Samsung instructions from here Once in Safe mode give it a try and see if it works now. If so, you know that you have a bad 3rd party App on your phone. It will not tell you which one so you will have to delete one after the other until you find the one that causes this issue.
If it does not get better in Safe mode, it is not an App etc. and you can exit safe mode.
Check the Bluetooth firmware version of your phone by dialing ****#2663#*** and see if it shows up properly. ******Anything after that would lead me to having to check the components on the board. Looks like your phone is a SM-G977. There are no free schematics out there but you can can get them through fee-for-service $$
这个答案有帮助吗?
Try wiping the cache partition and check if that resolves the problem.
Go to Wipe Cache Partition → Samsung
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 438
5条评论
Did this happen after an update?
由 Markus Norstrøm 完成的
Please see if phone reset helps
由 Asha Kanta Sharma 完成的
@oldturkey03 I highly appreciate the feedback, I just tried the Safe mode trick and still had no luck. I now strongly believe that the issue might be hardware related.
由 Bwalya Mataka 完成的
@markusnorstroem Not necessarily, I used the phone for over a year and a half with the latest update. I believe the issue might be hardware related.
由 Bwalya Mataka 完成的
@i_am_the_cosmos unfortunately that did not work, I tried a network reset and still had no luck. Thank you for your input
由 Bwalya Mataka 完成的
