跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-TZ5 发布于 2008 年 3 月。它是 TZ 系列的第三款相机,拥有 3.0 英寸显示屏、28-280 镜头(10 倍光学变焦)和 910 万像素。TZ5 还具备 720p 高清视频录制功能。
camera wont turn on!
i need help my camera wont turn on i replaced battery and charger and still wont turn on when i bought it it worked then i stored camera for about a year then i try to turn on and it wont
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Start of with making sure that your battery contacts are all clean, that there is no corrosion or debris present. You may have to disassemble the camera to get to the contacts. I would also make sure to change the Lithium battery at component side of Top Operation PCB. Once you have the contacts cleaned and the battery makes good contact, reevaluate. It is unlikely that you have any damage to the flex or the PCB from just storing the camera.
UPDATE
There are two fuses on your PCB that you could check. Use a multimeter and check for continuity.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
brandon Munoz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 4,282
