跳转到主内容
加入维修社区 - 创建账户
第十代 Corolla (E140/E150) 于 2006 年 10 月在日本发布。日本市场提供窄体版,国际市场则销售宽体版本。
Intermittent cranking no start
Car does not start but will crank I have checked Sparks battery ignition coils what else could there be
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@debfinnegan you mentioned that you have "checked Sparks battery ignition coils" but did not tell us if you do have a spark when the engine cranks over. You need air, fuel and spark to fire the engine. You most likely have air and if you do have sparks then the issue would be fuel or it does not spark at the right time.
Let us know what exact year and engine size your Corolla is. From what you are describing I would take a closer look at the crankshaft and the camshaft position sensor.
这个答案有帮助吗?
得分 0
添加一条评论
"Intermittent cranking" and "will crank" are mutually exclusive.
If it cranks normally, the battery is OK. If it is intermittent you could have a number of problems.
If it won't start and you have spark while cranking, and it never makes any sign of starting, then turn your attention to fuel injectors, fuel pump, or empty tank.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deb Finnegan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 351
