跳转到主内容
加入维修社区 - 创建账户
Asus ZenBook Pro Duo UX581GV 发布于 2019 年,是一款独特的笔记本电脑,配备了 15 英寸主 OLED 触摸屏以及位于键盘正上方的辅助触摸屏。
Do I need to replace my screen?
My laptop developed this bright area across the entire screen.
Not sure if I need to replace the video card or the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Have the same issue since Friday - did you manage to resolve it?
Note it is only on the main screen, I have 3 other UHD screens attached with no issue.
Thanks,
W.
由完成的
Hello. I also have the same issue. I don't know if I should buy a replacement screen from Amazon and install it. I'm afraid the quality won't be the same as the original, what do you think ?
由完成的
添加一条评论
1个答案
已选择的解决方案
@tanyarey it does not look like a video issue but more like a display issue. One thing to try is to attach an external monitor. If that displays the same line, it's your GPU circuitry (video circuit is built into the motherboard, it does not have a separate video card). If the external monitor does not show that line, it is your display that needs to be replaced.
这个答案有帮助吗?
得分 2
4条评论:
Is this common because I have the same issue. I turned it on one day and it was just there.
由完成的
@tmeverything heat and "high miles" are the most common causes for this. It is really not the screen itself but the components and solder on the driver boards. LCD screens are actually quite complex and sensitive.
由完成的
Can GPU circuitry be fixed or is the laptop busted @oldturkey03 ?
由完成的
@shanicecoleman it'll depend on the motherboard and which component has failed. Sometimes it's just a small SMD component that needs to be replaced and other times it is the GPU itself which might be difficult to replace.
由完成的
添加一条评论
添加你的答案
Tanya Rey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 22
总计 847
