跳转到主内容
How do I reapply thermal paste on this laptop?
Hello, my laptop's CPU often heats up to 70-80 when gaming, this did not happen before. I want to reapply the thermal paste on the CPU with hope of it lowering these temps. When i search on google i get multiple different answers as to how i should apply the thermal paste, and which thermal paste i should use (Some even recommend thermal pads)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @superres7
Here's the hardware maintenance manual for the laptop.
First go to p.60 to see how to disable the built in battery and then go to p.66 to view the procedure to remove/replace the thermal fan assembly so that you can refresh the thermal paste on the CPU.
If necessary you can also clean the fan once it is removed from the laptop as well.
Here's the ifixit 如何涂散热膏 guide that may help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
SuperRes7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 81
