跳转到主内容
加入维修社区 - 创建账户
适用于索尼第一代 RX100 高端紧凑型相机的维修指南和支持,该相机配备 2020 万像素传感器。Sony Cyber-shot DSC-RX100 发布于 2012 年 6 月。
Dropped camera - not powering on
I dropped the camera without protection on stone floor. A small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much. The power isn’t turning on and when I try to charge it, no light is glowing. All mechanical components are operational and the battery looks intact. Any idea what the problem might be and if it is fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@jacobvedholm this "small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much." we would have to seethe damage to evaluate it. If you have no power at all it is possible that you have a couple of torn/loose ribbon cables or worst case scenario; a damaged board. If it comes on but turns off it could be the lens. A lens that does not retract or extended will get the camera to turn off.
在已经存在的问题里加入图片 TO work on your camera you can download the SM from the Documents part on this page Sony Cyber-shot DSC-RX100 level 2 is the disassembly etc. and Level 3 are the schematics etc. Let us know and see what you find out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob Vedholm 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 1,088
