跳转到主内容
加入维修社区 - 创建账户
Hover-1 Chrome 平衡车内置了蓝牙扬声器。本页面包含有关各种 HY-CHR 型号的信息。
Strippted screw on a hoverboard
How to fix a stripped screw on hoverboard
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Yeah, so a trick I've found useful is sticking a rubber band between the screwdriver and the stripped screw. It gives you a bit more grip to turn it. And if that doesn't work, you could try using a slightly bigger screw if there's room in the hole.
这个答案有帮助吗?
得分 1
添加一条评论
A variety of suggestions in the Restarters wiki at https://wiki.restarters.net/Rescuing_Dam...
这个答案有帮助吗?
得分 1
添加一条评论
Is it stripped at the screw's head where the screwdriver goes? Or is it stripped inside the device where the screw threads are?
这个答案有帮助吗?
得分 0
2条评论:
The head is stripped
由完成的
Thank you for clarifying your screw situation so we can answer
由完成的
添加一条评论
@siuuffv depends on the diameter of the screhead. If it is large enough use a drill. Choose a bit that is about 2/4 the size of the dia,etr of the screw head and then gently drill deep enough until the screwhead will separate from the rest of the screw. Then, once you have the case apart, use a pair of pliers to remove the leftover stub. Hardest part is to keep the drill steady and as centered on the screwhead as possible so it does not run off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Siuu ffv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 443
