跳转到主内容
加入维修社区 - 创建账户
TCL 于 2018 年发布的 32 英寸 Roku 电视。
No image black screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 16
18条评论
由完成的 分享
@edwinlombeh have you tried the steps listed in the answer?
由完成的 分享
the television does not turn on, but the power on light
由完成的 分享
No display only stay on
led indicator
由完成的 分享
Tidak ada gambar pas pakai sate box
由完成的 分享
显示更多的13条评论
添加一条评论
1个答案
最有帮助的答案
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
这个答案有帮助吗?
得分 6
5条评论:
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
由完成的 分享
yes me too can i get a guide on hoe to fix it
由完成的 分享
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
https://www.youtube.com/watch?v=I32MBlbR...
https://www.youtube.com/watch?v=QdxSHeQF...
由完成的 分享
Full black image
由完成的 分享
@venu72785 what have you checked and what have you already tried?
由完成的 分享
添加一条评论
添加你的答案
cristine joy catuboran 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 184
总计 5,671
