跳转到主内容
加入维修社区 - 创建账户
Ridgid R4092 瓷砖切割机是一款多功能设备。该切割机能够切割天然石材、铺路石和瓷砖等多种材料。它能够切割 34 英寸的大尺寸瓷砖,以及 24 英寸的对角线瓷砖。它结合了激光导引装置、优化的喷水系统和斜切导轨。
On off switch not working
On off switch stays in on position
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@tracystone verify for us that yours is a Ridgid Tile Saw R4092
由完成的
添加一条评论
2个答案
已选择的解决方案
Is the switch physically unable to move, no matter how hard you push? If that's the case, I would suggest finding a replacement switch and replacing it if you're comfortable doing so. A switch that is physically stuck could be caused by multiple things, one possibility being that it has melted on the inside. Hence I do not recommend trying to fix the switch itself as it's not only difficult but could be dangerous if done incorrectly
这个答案有帮助吗?
得分 0
2条评论:
It pushes in and pop back out
由完成的
And does the unit turn on momentarily when it's pushed in? If so a spring lock mechanism might have gotten damaged inside the switch. Replacing it is the way to go! :)
由完成的
添加一条评论
@tracystone sounds like this is a bad switch. It is okay to replace, just make sure you unplug your tile saw first. The replacement part for the R4092 is Ridgid part number 089041034151 and it is readily available. The switch itself is held in place by some spring tabs. All you have to do is use a screwdriver and lever it out of the socket.
Here is the R4092 Parts And Repair It does include the wiring diagram.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tracy Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 49
总计 1,321
