跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A20 于 2019 年 4 月发布。它拥有一块 6.4 英寸的屏幕,背面配有双摄像头。
A20 keeps rebooting randomly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@ssaammss random is always a pain to figure out. I would suggest that you start your A20 in safe mode and see if that resolves this. If so, then the issue could be a recently uploaded App. You do need to uninstall those one after the next until it is resolved. To get your phone into safe mode, use the directions from Samsung
If safe mode does not check your phones settings and see if there is a Software update that is available. Update your software if one is available.
Now you can try a factory reset to see if that will resolve it. Just remember that you need to remove the google password before resetting your phone. You will lose all of your images, contacts SMS etc by doing this. Make sure you have a backup of those.
  1. Navigate to Settings. and tap on it.
  2. Tap on General management .
  3. Tap on Reset .
  4. Tap on Factory data reset .
  5. Tap on Reset .
  6. Tap on Delete all .
from here
From a hardware perspective , this could most certainly be a bad battery as well as a loose flex cable from the charging board. Since iFixit doesn't yet have a guide for this, use the one from here as well as this one. I would even do this before doing a hard reset, unless you have your files all backed up. Then it won't matter :-)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 853
