跳转到主内容
加入维修社区 - 创建账户
Game Boy 于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
Gameboy screen stuck on case
So I opened up my GameBoy and when removing the board with the screen I pried it loose with the plastic tool I bought.
However, unlike any tutorial, the screen remains stuck to the casing instead of coming out together with the board? I re-inserted the screen ribbon and device powered on perfectly, then I removed the batteries and tried again to get the screen out. After the second try failed as well I tried turning the device on but nothing is happening? Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@ezekiel9898 unless you are the original owner and know what repairs have been done on this, it could be tricky. There is always a chance that somebody got wild with same crazy glue or similar. Get some high grade isopropyl alcohol 95%+ and a syringe. Then inject some of the alcohol between the case and the frame of the display. See if that softens things up. Bottom line here is that you may potentially lose the display since it may crack.
Post some pictures of what this all looks like so we may come up with more "ideas" on how to help you with that. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ezekiel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 279
