black screen no power
phone turned off and will not power back on but vibrates like it wants too
@adammckim this " but vibrates like it wants too" is usually what happens when you have a broken screen. It will only vibrate. Consider replacing the display
这个答案有帮助吗?
Hi Adam,
If your phone still vibrates, it most likely means the screen is just dead.
as your phone is likely still under warranty, you should be able to take it to Samsung and they will replace it for you.
otherwise, you can have a 3rd party repair shop do the repair or simply do the repair yourself. Luckily this is quite easy on most Samsung A-Series phones.
If you want to attempt the repair yourself, you'll either need a new LCD panel or whole replacement frame with the LCD included.
I would recommend just replacing the panel, as Samsung LCD panels tend to be rather robust. It will also save you from the extra risks and complications involved in transferring components over to the new housing. I will paste links to both the panel and housing with the panel included as well as a guide on doing this repair.
Please note that performing the repair yourself or having a repair shop do the repair for you will most likely void your phones warranty.
Panel: OEM For Samsung Galaxy A14 5G SM-A146U A146U1 LCD Touch Screen Digitizer 40PIN
Housing: For Samsung Galaxy A14 5G SM-A146B OEM LCD Screen with Frame
Guide: Samsung GALAXY A14 5G - Repair a cracked glass / screen - YouTube
hope this helps, let me know if you have any other questions :)
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 52
总计 914
