跳转到主内容
非一体化电脑称之为台式机。
Keyboard + mouse connectors problem
I got this PC Compaq Presario 7170, which had a problem with mouse port. It didn't work. Serial mouse is working.
I replaced both ports and soldered a new ones, but since then my keyboard is also reporting a problem on boot - Keyboard error. But it works. If I press any of the keys with led light (num pad, caps lock or scroll lock) keyboard stops responding. I need to unplug it and plug it back in to make it work again.
Even though my soldering is terrible, I checked all the leads and everything is connected. I also checked surrounding caps and resistors and they seams fine. At least, what I know to check.
Any idea where I could go next?
Update (12/29/23)
Here is maybe better photo:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Yes the new photo helps a lot! Sorry, but your solder connections look terrible. You may have a "cold" solder joint by looking at them.
I would neaten up the solder points by just touching it with the soldering iron until it flow and then slowly pull the iron away. Don't overheat and pull the iron away as soon as the solder flows. This could possibly be part of your problem ???
My motto is always look for the simplist solution first. You what is different and what did yo acyually do? You soldered so look there first.
It could be another component but start with the soldered connection.
完成的
No need for sorry, I know it is terrible. My soldering wire was too thick, but now I got a better one.
If there is a cold soldering, it wouldn't beep from the conector till the wire on the board (where it is stripped). Soldering point is between those two
完成的
添加一条评论
4个答案
已选择的解决方案
Ok, so the problem was this component right here:
The voltage was dropping on it, so I removed it (wire jumped) and now everything is working. Including mouse. :)
这个答案有帮助吗?
得分 1
1条评论:
Good. Well done.
完成的
添加一条评论
最有帮助的答案
Maybe the solder is causing a minor short. Check with a multimeter but first clean up area on board. The photo is not very clear or my eyes aren't so good (grin). May sure the circuit board is clean around the solder points. Important - 99% (no water or minerals to short things) Isopropyl alcohol is good for cleaning. Are you sure it wasn't the mouse itself that was the problem rather than the port?
Of course the problem may be other components on the motherboard and it is close to 30 years old.
This site may help you better:
这个答案有帮助吗?
得分 1
1条评论:
Yes, I used IPA 99% to clean everything. No mouse was ok as it works on other PC and I tried 3 different ones. I checked each point and there is no short. Maybe I burned some component on the other side, but not sure where to look.
完成的
添加一条评论
I just discovered that I have 2.5V between DCC and ground pins on the keyboard connector. Based on the schematic, it should be 5V.
Could this be a issue and what can I do to track down this problem?
这个答案有帮助吗?
得分 0
添加一条评论
Update: I have 5V when the keyboard is not connected, so that should be fine. But I red online that this could be due to faulty transistor that controls the voltage. Now I should find this transistor but I don't know how. :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Slobodan Maric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 62
