跳转到主内容
加入维修社区 - 创建账户
压力锅、电饭煲、慢炖锅及其他各类厨房炊具的维修信息和拆解指南。
F3 LED code on Aroma rice cooker
Hello I'm new to this forum so my bad if I break some rule.
I got an Aroma rice cooker
Model No. ARC-1030SB
Things been throwing up F3 error on the LED when I tried using it yesterday, now I did some digging around online and found out it's for something related to overheat sensors in the unit. Now as for as my knowledge goes I'm just an avg consumer (even though I hate to admit it) with no knowledge about how to go on with this, or even what to do to fix it, if that's even possible at this point.
I have already tried to typical plug, restart, plug back in couple of times
Already tried cleaning the thing to make sure there's no gunk
Already tried messing around with some buttons
So this is kind of my last ditch effort to post here before I add this unit to the global e-waste bin somewhere in the ocean and move onto a newer model. Any help or advice would be appreciated, thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
When did you purchase this rice cooker? If it was within 1 year then it is possible to file a warranty claim with Aroma.
完成的
That's out of question now, it's already heading to 1 and a half year. I would like to try and make an effort to manually try fixing the thing if that's possible with F3 codes. But I just don't see any guide or step by step process to doing that.
完成的
添加一条评论
2个答案
最有帮助的答案
Guide still a work in progress. Steps are all there, just need pictures and maybe a video.
Update - Feb 5, 2023 - I finished taking pictures and have refined the guide just a tad bit. But should be good enough to call it complete now. Feel free to let me know if anyone needs any clarifications or anything to add.
Aroma ARC-1030SB F3 错误修复
这个答案有帮助吗?
得分 3
2条评论:
@lolue I like it! very good and awesome of you to have done that. We appreciate that!
Repair is War on Entropy!
完成的
Thanks you !!! I had the same F3 problem and I already solved it.
完成的
添加一条评论
@jakeleo The F3 error shows as a : Top sensor short-circuit. Now we just have to find out how to tear it down and to find the sensor :-)
这个答案有帮助吗?
得分 2
8条评论:
That's something but I don't know where to start, is there any step by step guide out there? cause I'm definitely willing to give it a try, just once again because of my limited knowledge in this tech I'm just lost.
完成的
@jakeleo post some good pictures of your rice cooker with your question. Let's see if we can figure out how to disassemble it :-) 在已经存在的问题里加入图片
完成的
Is there still a need for help with this? I have the same cooker and have fixed this issue twice. I can write up instructions and provide pictures if needed.
完成的
@lolue that would be awesome! Create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
完成的
@lolue Sure, it would still help if I can get any guide.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Jake Leo 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 133
总计 5,968
