跳转到主内容
Great vacuum and easy to repair.
1 个问题 查看全部
Why won't my vacuum turn on?
Oreck won't turn on and handle power switch doesn't illuminate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The electrical connector to the switch itself may be disconnected inside the handle.
  • After the obvious try a different outlet, verify the cord is plugged in both ends.
  • The connections to the illuminated switch in the handle are pressed on. After repeated dropping of the handle onto the floor, a switch connector may have fallen off the switch.
  • Unplug the unit and remove the screws holding the two sides of the handle together. Locate the loose wire and plug it back into the switch lug.
  • Loosely assemble the handle, plug in the vac and give it a try. If it turns on tighten the screws.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Randy Tolleson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 53
总计 1,007
