跳转到主内容
加入维修社区 - 创建账户
Acer Aspire V5-471 是一款 14 英寸经济型笔记本电脑,专为学生和日常用户设计。它采用英特尔酷睿处理器和集成英特尔高清显卡。本页面提供维修、故障排除、零件更换和技术规格方面的支持。该设备的其他型号名称可能包括 V5-471-6614 和 V5-471-6888。
change hdd to ssd problem
My Acer V5-471 laptop: I replaced the HDD with an SSD, but the laptop didn't work at all. The power button shows a blinking blue light quickly, and the laptop doesn't turn on. When I reverted to the HDD, it worked normally. Is there a solution or explanation for this issue?"
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mustafameddah do you have an OS on the SSD?Since you did not give us a lot of detail, I'd check on this. It is possible that your computer does not detect an OS and treats the POST as a failed drive. You will need to set your BIOS to boot from something like a bootable USB drive and install an OS to the SSD
这个答案有帮助吗?
得分 1
3条评论:
the ssd is new there is no os on it and it is not partitioned yet
the problem is that the pc doesn't turned on at all now bios shows up or nothing when it press the power button a blue light on the power starts blinking very fast that's it. i cant get to the bios or nothing else the screen black and the fans doesn't start at all
由完成的
@mustafameddah but all that works again when you reinstall your HDD? If so, you do know that the issue is with the SSD.
由完成的
@oldturkey03 yes because it's new and still not identify as mbr or gpt and still not partitioned yet i took the ssd and palced it on my desktop pc make it mbr split it to one part of 100 gb installed windows 10 and took it off and put the ssd again on the pc acer that it didn't work and it started normally thank you for the reply back
由完成的
添加一条评论
添加你的答案
mustafa meddah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 42
总计 487
