跳转到主内容
加入维修社区 - 创建账户
Toshiba 40PB200 是 PB200 系列中的一款 40 英寸平板电视,于 2012 年发布。
Screen and nothing working
Nothing working eventhough we connect to the power the light also not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@kdhineshka22226 it sounds like you are saying that your Power LED is not showing that power gets to the TV. If that is so, then check your power outlet, your power cable and make sure it is plugged in. If it is, the the issue is most likely with your power board. For that you will have to remove the rear cover from your TV. Unplug it, remove the cover and check the board. There should be a fuse right by the power cord connector. Check that fuse for continuity.
After that, take a couple of good pictures of all of your boards and post those with your Question. That way we can see what you see and hopefully help you to fix your TV. Also, let us know the exact model of your Toshiba TV.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
K.DHINESH KAARTHIK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 281
