跳转到主内容
加入维修社区 - 创建账户
All wireless functions lost
Hi, my Bose Soundlink work fine when plugged into the laptop jack (whether switched on or off!) but all wireless funtions have stopped working. As I used to use these with my iphone via Bluetooth, how can I figure out if it's a charging issue, or a problem with Bluetooth? Hope you can help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@tim75247 since it "work fine when plugged into" but not with wireless I would start with a new battery. IF it still does not work, then you will need to tear it down further and check the circuitry. The battery should be in the Left side. You should have 4 screws under the ear cushion. 2 of those are regular Philips head screws and two are proprietary safety screws. You may need to try different screwdrivers for those (T5) to see if you can remove those.
If you are stuck with anything post a couple of pictures with your Question of where you are stuck at and hopefully we can assist you further, 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 248
