跳转到主内容
加入维修社区 - 创建账户
Display is not comming.
Power is on, sound is comming but Display is not comming.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Ashish, what's the model number of your television? There are so many differences between TVs that we need to know what we're working with in order to help.
由完成的 分享
@ashish58011 As Jerry asked, what is the brand and model of your television? If you shine a flashlight onto the display, can you see a faint picture?
由完成的 分享
The screen is not showing but sound is comming
=== Update (11/08/25) ===
Yes the screen is not showing
由完成的 分享
@dharshandaya did you take the time to read the answer? Have you tried those thing? what was the outcome?
由完成的 分享
添加一条评论
1个答案
@ashish58011 First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Yes, We still need to know what exact Model your Vu television is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 41
总计 904
