跳转到主内容
加入维修社区 - 创建账户
won't power on
won't power on yellow light on power/standby, both lamp light red, temp is red and filter is yellow.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@nick you know a lot about these projectors. What's your take on this?
由完成的
John Umina... Were you able to solve this issue? Our same projector is giving me the same problem.
由完成的
添加一条评论
1个答案
@johnumina you got a lot going on here with the projector. Since all those lights seem to come on immediately, it appears as if you are having more of a firmware issue than the actual parts (both lamps, air filter and overheating) Of course, it is possible that it is those pats, just unusual. Also, the LEDs should be blinking and not be solid on, if they were to indicate a failure.
There is a way to connect a computer to the projector to access the error log, but not sure if it will work if this is a firmware (EEPROM) issue. Use the SM Panasonic PT DW640 to work on our projector, one step at a time. Check on here as well as on here to see if a firmware update is available and how to update.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JOHN UMINA 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 449
