跳转到主内容
加入维修社区 - 创建账户
任天堂2DS是一台掌上游戏设备,作为任天堂3DS的入门版本而开发,在硬件上与3DS完全相同,但没有裸眼3D功能
2ds camera error has accured
My 2ds camera works in the AR CARDS app but not in the 3ds camera and quick cam menu
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like the camera app itself is broken. Try safe mode. If that doesn't work, you'll probably have to factory reset it unless you have CFW.
If safe mode failed and you have CFW, you can try deleting the camera app, then updating the system to restore it. Launch FBI, then go to Titles > Nintendo 3DS Camera > Delete Title And Ticket. Press A to confirm, then update the console (you can use safe mode or the regular system update). The update will redownload and install the app, leaving you with a working camera
这个答案有帮助吗?
得分 2
3条评论:
The 2ds I had, I had sold, thanks for the answer I will use this information if I come across this again. I will accept your answer since it “worked”
由完成的
I did this, now instead of crashing it leaves a message saying "an error has occured, hold down the power button to reset" after reseting it still just has this message.
The error popup only happens when i try to use the inner camera, the outer works fine. I have a new 2ds xl.
由完成的
Hi!
In this case you most likely need to replace the inner camera. If you need guides, please let us know!
由完成的
添加一条评论
添加你的答案
Sqwerks 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 21
过去 30 天: 71
总计 3,380
