跳转到主内容
加入维修社区 - 创建账户
GE72 2QF Apache Pro 是微星(MSI)于 2015 年推出的 17 英寸笔记本电脑。它内置 IPS 显示屏和 GeForce 970M 显卡。
Battery change mAh difference - Will it work?
Hello everyone,
I finally got my 6 year old MSI GE72 2QE up and running again!
The battery was causing issues, so I removed it and now it works perfectly.
So I wanted to get a new battery, so my work won't get lost if I pull the plug or if there is a power outtage.
The battery there was IN the laptop ORIGINAL had 4730 mAH but the ones I see on EBAY is 5200 mAh, will there be any consequences with the difference in the mAh, since there also is a slight difference in the Volt and Ah (amps)
I am using below universal charger:
100-240V
2.2A - 50-60 Hz
19V - 7.89A
The original battery:
4730 mAH
51 Wh
10.86V - 4.73Ah
Replacement battery1:
5200 mAh
48 Wh
10.8V
Replacement battery2:
3834 mAh
41.40 Wh
10.8V - 3.834 aH
Since money is a bit short, and I want to get maybe one more year out of my MSI, I was thinking that a battery with shipping at 40€ is worth the deal.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@osuna15047 if the dimension of either one of the replacement batteries matches your original battery, and if the battery connector is identical, you can use either one. The voltages are within specs for your computer. the mAh just means how much energy your battery can store and supply, before it needs to be recharged. Of course, the larger the mAh, the longer it will also need to charge. You are fine with either one, for as long as the before mentioned connector etc. are identical.
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much for the answer, I wasn't 100% sure about it
完成的
添加一条评论
添加你的答案
Osuna 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 27
总计 390
