跳转到主内容
加入维修社区 - 创建账户
索尼于 2004 年 9 月发布的 PlayStation 2 (SCPH-700xx) 更小、更薄、更安静的型号。
What capacitor is this?
This is a photo of another board but on the board i am working on, the capacitor is leaking and needs to be changed. I am not sure what the capacitor is, does someone know what capacitor it is?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
@choukosenpai you do want to go ahead and post a larger picture so we can at least try to help you with to much eye strain :-)
What board number is this?
完成的
it is a SPCH- 77004 board, i would post a clearer photo of the component though the leakage of the component has removed the text ontop of the component. hopefully it helps
完成的
@oldturkey03 this is the closes schematic that i have found
https://gamesx.com/wiki/lib/exe/fetch.ph...
完成的
添加一条评论
1个答案
已选择的解决方案
@choukosenpai does not look like a capacitor at all. That looks like a coil. If you can post a bigger picture so we can see whatever it is that is printed on it, I am sure we can identify this component.
Update (10/03/23)
Thank you for adding the image to your Question. Like I suspected it is a coil. In this case it is a 3.3uH inductor. Now the only thing you have left is to measure the physical dimensions (width and length) This will be an easy part to source. Fairly straight forward repair too. What Country are you in (no details please) so we can try and find a supplier.
这个答案有帮助吗?
得分 1
10条评论:
i have added a new picture, the thing is that i cant get a close up of the component since the leakage of the component has removed the text ontop of it, that is why i said that it is another photo of the board (i have taken this photo from google)
完成的
完成的
@choukosenpai Ok let me look at this in a few hours. I am at a place right now that does not allow me to look at it. :-)
完成的
@oldturkey03 alright thank you,
完成的
@choukosenpai it's identified :-)
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Mr_Chou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 783
