跳转到主内容
加入维修社区 - 创建账户
Smoke from Air Compressor
I own a J5C09. I was just using the air compressor and as I was nearing the end/running out of charge, I noticed a small amount of smoke coming from the unit. I should probably note that I have used the unit mostly to inflate tires (as opposed to jump-starting). However, probably still less than a dozen times. Is my air compressor starting to die? If so is there any way to fix this, remedy or prevent it from happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@will6485 that is a difficult question since we really don't know what is going on with your power station. Smoke could have come from the battery or even from the compressor. Sometimes you just have to wait for things to break, before you know what needs fixing. Until you open it up and take a peek, it's all a guess.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 448
