跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad Yoga 370 是一款纤薄、轻便的超便携二合一笔记本电脑,配备 360 度铰链和支持多点触控的 AES 触摸屏,并可选配用于移动连接的 LTE-A。型号:20JH002AUS。
Device not switching on
  • Why is my PC not turning on and also not charging when connected to a power source?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I need an urgent reply 😭😭
由完成的
添加一条评论
1个答案
@lanry you are not really telling us a lot here. Would be nice to know what you have checked and if anything has happened to this Thinkpad. Anyhow, I suggest you start with the basics for all devices and check a few things.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lanry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 399
